Files
- 3 MB
- Download
This example demonstrates how to restore the original layers of the SketchUp file and how to represent them properly in a 3D PDF document. Since the Adobe PDF Reader supports layers and has the capability to show and hide them in the model tree, it can be very useful to preserve this structural aspect of the data.
The attached template workspace performs a SketchUp to 3D PDF translation. Download the template and open it up in FME Workbench. A closer look at the source SketchUp file reveals three different layer names. Layer 0 represents the terrain, Layer 1 represents buildings with heights below 40m and are colored red, and Layer 2 represents buildings taller than 40m, which are colored blue. This conditional layering is based on a previous example.
| SketchUp File Structure | What the Layer Represents |
| Layer 0 | Terrain |
| Layer 1 | Short buildings, red |
| Layer 2 | Tall buildings, blue |
There are three SketchUp layers in the source file. They represent three groups of data, the terrain, the short buildings, and the tall buildings.
Step-by-step Instructions
1. Read SketchUp File
Reading the SketchUp file results in only one feature because the layers are already merged into a single aggregate feature. In a simple workspace, with one reader and one writer, the resulting 3D PDF would contain only one layer. In this example and the attached completed template workspace, we will be using a more complex method with transformers to deaggregate, filter, and preserve the original SketchUp layers in the PDF output. The result will be a PDF document with three layers.
Add a reader to the canvas.
- Format: Trimble SketchUp
- Dataset: 3D_model.skp
3D visualization of the source SketchUp file viewed in FME Data Inspector.
The Record Information dialogue in the Data Inspector of the SketchUp file. You can see that although it reads it as one feature, the layer names are still stored in the aggregates of the source file.
2. Extract SketchUp Layer Names
To restore the layers, the layer names need to be extracted so that we can filter the geometries based on the different layers. Within the Record Information window, hover your cursor over the sketchup_layer_name trait to view the layer name stored as a trait on the IFMEFaces geometry within the IFMEAggregate feature, allowing it to be accessed and extracted later.
2.1 Break Up Aggregate Features using the Deaggregator
We will use the Deaggregator to split up the one aggregate feature into its components so that we can filter them into their proper layers later. Notice that we are using the Mode: Flatten One Level. This means that it will break up the source feature (the parts in the IFMEAggregate) by one level of aggregation, which then yields all the individual features seen in the output model in PDF later.
The template workspace provided of the SKP to 3D PDF translation. Notice that one feature goes into the Deaggregator and 9692 features come out, broken down by one level.
2.2 Extract the SketchUp Layer Names: GeometryPropertyExtractor
Next, the GeometryPropertyExtractor extracts the layer name into an attribute sketchup_layer_name for each feature (note that the GeometryPropertySetter can store this trait as an attribute for every single face).
- Trait to Extract: sketchup_layer_name
- Geometry Part Selection XQuery: click on the ellipsis (...) to edit
The parameters for the GeometryPropertyExtractor. We want to extract the layer names from the SketchUp file.
Set the Test Clause as shown below and ensure your Geometry Part XQuery Preview matches the reference image below.
- Left Value: Geometry Type
- Operator: =
- Right Value: IFMEFace
The expression for the Geometry XQuery in the GeometryPropertyExtractor transformer. It is set to IFMEFace, where the layer names are stored.
If you would like to view the output at this point, run the workspace with feature caching on, then go to the GeometryPropertyExtractor to inspect the Extracted output port. You will now notice that the table shows you 3 columns- the third being the sketchup_layer_name, where features belong to either layer 0, 1, or 2.
2.3 Filter the SketchUp Layers using the TestFilter
Finally, the TestFilter separates the three different layers from each other.
Set the Test Conditions as listed in the table below:
| Test Condition | Output Port | |
| If | @Value(sketchup_layer_name) = Layer0 | Layer0 |
| Else If | @Value(sketchup_layer_name) = Layer1 | Layer1 |
| Else If | @Value(sketchup_layer_name) = Layer2 | Layer2 |
Within each test condition, set:
Comparison Mode: Case Insensitive
- Features will pass the test condition regardless of whether the layer name begins with an uppercase or lowercase letter ‘L’
3. Extract Appearances
To demonstrate how to retrieve appearances of features and apply them to other features, the appearances for the buildings are simply swapped in this example. This will happen in two steps: (1) extracting appearance styles using the AppearanceExtractor and the Tester, and then (2) swapping the appearances using AppearanceSetters.
For extracting appearances, we will use two transformers:
AppearanceExtractor: to extract all parts from the front and back sides. By appearance, we are referring to the properties of the model like color, texture, transparency, and shininess to name a few. The output of the AppearanceExtractor does not include any geometries. Only appearance parameters or textures are stored in the output features.
- Keep Input Attributes: Yes
TestFilter : Since we have extracted all of the appearance styles, we want to separate them by layers. In the TestFilter we will test for Layer 2. Features that pass the test correspond to Layer 2, while those that fail correspond to Layer 1.
For If test clause, set:
- Left Value: sketchup_layer_name
- Operator: =
- Right Value: Layer2
- Comparison Mode: Case Insensitive
- Output Port: Layer2
Set Else test clause:
- Output Port: Layer1
4. Swap Appearances
Since we are swapping the appearances of the buildings, the short buildings (red) will now appear blue, while the tall buildings (blue) will now appear red. This swap is controlled by how the ports are connected.
In the AppearanceSetter parameters, set:
Appearance Storage: Replace Existing Definitions
- Replace the existing appearance stylings in the layer with a new one, allowing it to override existing styles.
In the image above, features of Layer1 are connected from the TestFilter (top left) to the Geometry port in the AppearanceSetter. The appearance of Layer2 from the Testfilter_2 (bottom left) is then used to define the Appearance in the same AppearanceSetter. The same concept is applied in the second AppearanceSetter, swapping the appearances between the other two layers.
Another way to picture this is:
| SketchUp Layer Name | What the Layer Represents | Original Appearance | New Appearance |
| Layer 1 | Short buildings | Red | Blue |
| Layer 2 | Tall buildings | Blue | Red |
5. Write to 3D PDF
All output layers for the 3D PDF document are represented by a single destination feature type. By using the fanout by attribute option in the destination feature type parameters, feature types can be created based on the sketchup_layer_name attribute from the input.
Add a writer to the canvas:
- Format: Adobe 3D PDF Writer
- Dataset: 3D_model_3DPDF
For Feature Type:
Layer Name: sketchup_layer_name
- Connect to the outputs of the AppearanceSetter if sketchup_layer_name attribute value is not visible.
6. View the Output
3D PDF data is best viewed in Adobe Reader. It’s generally a good idea to keep your Adobe Reader version up to date if you are going to work with 3D datasets.
Completed Workspace
Results
The result is a 3D PDF with the appearances for tall buildings and short buildings swapped. The buildings with a height greater than 40m are now red, while the buildings shorter than 40m are now blue. Congratulations! You have written out a 3D PDF that preserves the layers of the original SketchUp file.
If you have issues navigating the model view, right-click on the main display > Part Options > Fit Visible to lock and center the view on the currently visible layers. If the Model Tree toolbar in the PDF is not immediately visible when you open the file, right-click on the image and select ‘Show Model Tree’.
Data Attribution
