Files
This exercise is fairly advanced. It will cover bit masks, bit shifts, and logical operations. Here, we will examine supplementary information that Landsat collects and calculates to support the data quality assessment (QA). You can read more about working with Landsat's QA in this guide from Landsat.
What is the QA Band?
From the Landsat Quality Assessment (QA) Tools User Guide: "Each pixel in the quality assessment band (BQA) contains a decimal value that represents bit-packed combinations of surface, atmosphere, and sensor conditions that can affect the overall usefulness of a given pixel."
Knowing this, we can color the image based on these values. The integer numbers here are really just representations of binary strings, where each 0 or 1 (or pair) has a specific meaning.
Using a simple 4-bit example:
Integer - Binary String
0 - 0000
1 - 0001
2 - 0010
3 - 0011
4 - 0100 We can say, for example, that the first bit (0 or 1) from the right represents:
Data Present: 0 = no data, 1 = data; the second bit can mean snow, the third cloud, and the fourth water.
If we look at the integer '3' above, we can say the following based on the 0011 binary string: Going from right to left - Yes, we have data (1), yes, there is snow detected (1), no clouds (0), and no water (0).
Here is a handy online service that can convert decimal to binary and back.
Step-by-step Instructions
1. Add Landsat Data
Open FME Workbench and start a blank workspace. Add a GeoTIFF reader to the canvas and browse to the LC80470252014258LGN00_BQA.TIF dataset, which is available for download from the Files section of this article. This is a quality assessment band.
2. Inspect Cell Values
Before we go any further, let’s explore the data. Inspect the GEOTIFF reader feature type by single-clicking on it to open the pop-up menu, then click on View Source Data. With the data open in Visual Preview, explore the properties using the Feature Information window.
Notice that there is only a single GRAY16 band and no palette.
3. Convert GREY16 to UINT16
Let’s convert the GREY16 band to UINT16 so that we can use the UINTasBINPaletteAdder custom transformer to manipulate the binary values. Add a RasterInterpretationCoercer to the canvas and connect it to the GEOTIFF reader feature type. In the parameters, change the Destination Interpretation Type to UINT16.
If we inspect the raster now, it will appear as though nothing has changed yet, except for the band interpretation.
4. Add a UINTasBINPaletteAdder
Add a UINTasBINPaletteAdder custom transformer to the canvas and connect it to the RasterInterpretationCoercer. Before we run the workspace, let’s investigate what this transformer is doing. Right-click on the UINTasBINPaletteAdder and click Edit. This is a large workspace, but find the AttributeCreator_7 and open the parameters.
This equation seems intimidating, but it is actually a concatenation of simple expressions that use bitwise operations.
@Evaluate(@Evaluate((@int64(@Value(_elevation))>>15)&1)@Evaluate((@int64(@Value(_elevation))>>14)&1)@Evaluate((@int64(@Value(_elevation))>>13)&1)@Evaluate((@int64(@Value(_elevation))>>12)&1)@Evaluate((@int64(@Value(_elevation))>>11)&1)@Evaluate((@int64(@Value(_elevation))>>10)&1)@Evaluate((@int64(@Value(_elevation))>>9)&1)@Evaluate((@int64(@Value(_elevation))>>8)&1)@Evaluate((@int64(@Value(_elevation))>>7)&1)@Evaluate((@int64(@Value(_elevation))>>6)&1)@Evaluate((@int64(@Value(_elevation))>>5)&1)@Evaluate((@int64(@Value(_elevation))>>4)&1)@Evaluate((@int64(@Value(_elevation))>>3)&1)@Evaluate((@int64(@Value(_elevation))>>2)&1)@Evaluate((@int64(@Value(_elevation))>>1)&1)@Evaluate((@int64(@Value(_elevation))&1)))Taking one part of this as an example, we can find the following:
@Value(_elevation))>>3)&1_elevation, in this case, is our pixel value; let’s say we have 216. This corresponds to a binary value of ‘11011000’ (you can verify this using the converter above).
The next part (216 >> 3) performs a logical bitwise right shift operation, which shifts the binary to the right three places, so 11011000 (or decimal 216) becomes 00011011 (or decimal 27).
The final step (27 & 1) compares the binary strings using the bitwise Logical AND operation. We compare 11011 (27 without the leading 0s) to 00001. This results in 00001 (or 1 without the leading 0s).
By combining all the expressions, we obtain either 0 or 1 for each of the 16 expressions; the concatenated result is the binary representation of the original pixel value. The binary number is then passed to a StringFormatter, which pads it to 16 digits by adding leading 0s as needed.
Each bit represents the following:
You can also check out this PDF guide from Landsat for more information on how to interpret the bits.
5. Inspect Mask with Palette
Close the UINTasBINPaletteAdder edit, then add an Inspector to the UINTasBINPaletteAdder output port. Run the workspace and view the output in Visual Preview. In the Feature Information window, you will see a palette and the values converted to binary.
6. Add Color
Finally, let’s add some color to this raster. Add an AttributeCreator to the canvas and connect it to the output port of the UINTasBINPaletteAdder. Create a new attribute called _palette. Then, for Value, open the text editor by clicking the ellipsis. We can create a palette by copying and pasting the RGB triads below:
RGB24
1 0,0,0
20480 0,0,0
20512 0,255,0
20516 200,200,255
23552 127,127,127
28672 255,127,255
28704 255,127,255
36864 127,127,127
36896 0,255,0
39936 127,127,127
45056 255,127,255
53248 255,127,0
53280 255,127,0
61440 255,127,07. Add Palette
The final step before viewing the results is to add the newly created palette to the raster image. Add a RasterPaletteAdder to the canvas and connect it to the AttributeCreator. In the parameters, set the Palette Attribute to _palette.
8. Run the Workspace and View Results
Add or move the Inspector to connect it to the RasterPaletteAdder, then run the workspace. View the output in Visual Preview.
In the Feature Information window, we can see that the raster has two palettes, one containing the binary string and one with the RGB colors we created. The majority of the image is green which corresponds to a high confidence of vegetation, we also see some detection of snow or ice represented by the greys and in the top right region, we can see some pink which represents the presence of Cirrus clouds.
