FME Server ships Apache Tomcat as the FME Web Application Server Service. Whenever a request is made within FME Server, it returns a response. As part of this response, non-standard headers can be enabled for enhanced security.
If you have performed a security penetration test against FME Server and have been unable to find remediation steps to one or more of the reported issues on the FME Community, please contact Safe Software Support.
How do I enable an HTTP response header?
X-Content-Type-Options
To enable this header, please follow the instructions below:
- Run a text editor as an administrator and open the web.xml file located in <InstallDir>\Utilities\tomcat\conf
- Remove the comment block characters <!-- --> (or # characters from the beginning of each line) to uncomment:
<filter> <filter-name>httpHeaderSecurity</filter-name> <filter-class>org.apache.catalina.filters.HttpHeaderSecurityFilter</filter-class> <async-supported>true</async-supported> </filter>
- Also, uncomment:
<filter-mapping> <filter-name>httpHeaderSecurity</filter-name> <url-pattern>/*</url-pattern> <dispatcher>REQUEST</dispatcher> </filter-mapping>
- Save this file and restart the FME Web Application Server Service.
- To verify this change has been applied, open the FME Server Web UI > Developer Tools > Network > Click on a request > Headers > and you should see the header X-Content-Type-Options:nosniff
Note: Please be aware that when this header is set, that is, sniffing content is disabled, for jobs that are run under the Data Streaming Service, if the mime type of the response has not been set correctly the output will not display in the browser and instead revert to downloading the file.
X-Frame-Options
Follow the instructions documented on FME Server Apache Tomcat Vulnerability with X-Frame-Options header to enable this header.
Strict-Transport-Security
To enable the HSTS header, FME Server must first be configured for HTTPS. Once you have set this up, follow the instructions below:
- then above the <async-supported> tag add:
<init-param> <param-name>hstsMaxAgeSeconds</param-name> <param-value>31536000</param-value> </init-param>
- Lastly, uncomment:
- Restart the FME Web Application Server Service.
- To verify this change has been applied open the FME Server Web UI > Developer Tools > Network > Click on a request > Headers and you should see the header strict-transport-security: max-age=31536000
Content-Security-Policy
The CSP header is not supported by Apache Tomcat’s in-built filters; for this reason, it is not currently possible to enable this header.
To request support for this header, please contact Safe Software Support and quote FMESERVER-13532. Your case will be assigned to the internal ticket and you will be notified if this is resolved.
Comments
1 comment
It seems important to mention that X-Frame-Options and Strict-Transport-Security Headers go hand in hand because they are both managed by the httpHeaderSecurity-Filter. The doumentation on this page for configuring Strict-Transport-Security is a little bit misleading:
It assumes httpHeaderSecurity filter is not yet activated and simply following this guide breaks parts of the FME Flow web interface (job history dashboards which are embedded as frames). This is due to the circumstance, that without explicitly setting antiClickJackingOption=SAMEORIGIN (or custom origin), activating the httpHeaderSecurity implicitly activates the default value of antiClickJackingOption which is DENY. This prevents FME Flow to embedded its own content…
