FME and GPS
Liz Sanderson
Liz Sanderson
Global Positioning System (GPS) is a satellite-based navigation system that uses a receiver and four or more satellites to determine position anywhere on Earth. The term GPS used to refer only to the United States satellite system, part of the GNSS (Global Navigation Satellite System), but it has become interchangeable with satellite navigation systems from other countries. These satellite navigation systems include: GNSS (North America), GLONASS (Russia), Galileo (European Union), BeiDou (China), NAVIC (India), and Quasi-Zenith (Japan). Note that this article uses GPS to refer to the GNSS satellites, your GPS device might be able to use the other systems, consult your device’s documentation for more information.
Knowing your location, or your asset's location, is vital. Using a GPS receiver and satellites determines location accurately (exact accuracy measurements can vary significantly between device brands). Collecting the data is the easy part, being able to use the data in a meaningful way is where things become tricky, that’s where FME comes in.
FME can interact with GPS data in three main ways. The first way is to read GPS data directly using brand-specific format readers like Trimble, Garmin, or ArcPad. The second way is to export the data from your GPS device in a generic GPX, KML, XML, or CSV format and then read it into FME. The third way is to connect to your device’s API. This article covers all three methods and provides additional resources to learn more.
Brand-Specific Data Formats
Depending on the brand of GPS device you are trying to read data from, you may need to install a free plugin called GPSBabel first. GPSBabel is a free, open-source plugin that works with any operating system. After you install it and restart FME, the formats will be available to use. If you are having issues with FME and GPSBabel, contact Safe Software Support. Consult the documentation for your specific GPS brand to determine how to export the data. FME can also write out to all the formats listed below unless otherwise indicated.
Formats that can be read directly into FME:
Formats that require GPSBabel:
GPX, KML, XML & CSV Data
Some GPS devices or mobile apps can export GPX, KML, or XML data, which you can then |read ito FME using the corresponding readers. FME can also write to these formats, which you can then import into your device (if available). For more information on how to do this, see the following tutorials:
GPX
Reading GPX Data
Writing GPX Data
KML
Tutorial: Getting Started with KML
How to Convert KML to Shapefile
How to Convert Shapefile to KML
XML
Tutorial: Getting Started with XML
CSV
Tutorial: Getting Started with CSV
Build Road Lines from GPS Points (CSV to Shape)
Using an API to retrieve GPS data
Besides exporting data to a file, some GPS devices have an API that lets you retrieve data via an internet-connected device. Using FME and the HTTPCaller transformer, you can read and manipulate data from these APIs. To learn how to use an API in FME, see the following tutorials:
The following is a list of API-enabled GPS devices our customers have used. Please refer to your device’s documentation to learn the specifics about how to use its specific API:
Garmin:
John Deere:
RavenSlingshot:
SPOT:
Trimble:
If you have successfully used another GPS device with FME, please comment below, and we will add it to this list.
Additional Resources
[Question] Snapping GPS Trails to Road Centreline
[Question] Cleaning GPS Line Work
[Blog] GPS Meets Video. Do We Need a Standard for Geotagging Videos?
[Blog] CAT to GIS: Tracking Cats via GPS on Google Earth
[Video] iOS ARKit and FME - GPS hike and OBJ model
[Video] Episode 7: Coders on Couches Drinking Coffee - Georeferenced Video
[Template] Vessel Tracking & Navigation Data
