FME Desktop 2018.0+ cannot extend Autodesk Map 3D and Civil 3D
Liz Sanderson
Liz Sanderson
FME Version
  • FME 2018.x
As of FME 2022.0, the FME Integration Console will no longer be available in FME Desktop. For more information, please see the FME Integreation Console Deprecation article.
Affects
64-bit FME Desktop 2018.0 and greater.
Symptom
FME Desktop Integration Console does not give the option to extend Autodesk Map 3D or Civil 3D. In earlier versions of 64-bit FME Desktop, using a Professional Edition or higher, the “Autodesk Map 3D” and “Autodesk Civil 3D” would be listed in the FME Integration Console if the applications were installed on the machine:
Cause
FME Desktop 2018.0 and greater no longer extends Autodesk Map 3D or Civil 3D.
Workaround
The recommended workaround for this problem is to use FME Workbench to import the data into one of the following formats:
  • Autodesk AutoCAD Civil 3D
  • Autodesk AutoCAD DWF
  • Autodesk AutoCAD DWG/DXF
  • Autodesk AutoCAD Map 3D Object Data
  • Autodesk AutoCAD RealDWG DWG/DXF
Comments
0 comments
