Including the Log File with the Data Download Results
Liz Sanderson
Liz Sanderson
FME Version
  • FME 2020.0
When using the Data Download service in FME Server, additional files can be added. In this tutorial, we will add the FME Server job log with our download, which requires the FMEServerLogFileRetriever transformer. To add other files, please follow the Including additional files in the data download result zip file tutorial.
Step-By-Step Instructions
1. Open Template Workspace
In FME Workbench, open the Download_Logfile-Begin.fmwt workspace. This workspace writes a test message into a text file.
2. Add a FMEServerLogFileRetriever transformer
Now add an FMEServerLogFileRetriever transformer to the canvas and connect it to the Creator transformer.
In the parameters, set the Connection to your FME Server connection.
Then set the Job ID to the FME Server Job ID Parameter $(FME_JOB_ID). The parameter can be selected by clicking on the drop-down next to Job ID then going to User Parameter > FME Server Parameters > FME_JOB_ID.
Finally, change the Output Log Attribute to text_line_data. We need to change this attribute so that our writer in the next step will be able to read it. Click OK to save the parameters.
3. Add a Text File Writer
Now that the log file has been retrieved, we need to write it out. Add a Text File writer to the canvas. For the Dataset, browse to where you would like it to be saved, then name it job.txt, we will modify the filename in the next step.
Once the Text File writer is added to the canvas, connect it to the FMEServerLogFileRetriever transformer.
4. Create Fanout
When the workspace runs on FME Server, the data download file will contain the job.txt. Job.txt is not a very descriptive name, we can update this to include the log number and change the file extension to be .log.
In the Navigator window, expand the job [TEXTLINE] writer. Then double-click on Fanout.
In the Edit Job [TEXTLINE] dialog, enable Fanout Expression, then set the Fanout Expression to:
job_$(FME_JOB_ID).log
Now the file will be named job_1234.log or whatever number the current job is.
5. Save and Publish to FME Server
Save the workspace, then publish it to FME Server. When registering for services, ensure that Data Download is selected. Click the Edit button and then for Include Writers in Download, select both TEXTLINE writers.
6. Run the Workspace and View the Download
Log into your FME Server. Run the newly published workspace.
After it has finished running, click on the data download link to download the file.
Once downloaded, browse to the file and inspect the output to confirm the log file.
Comments
0 comments
