How to Create a SharePoint Web Connection for FME Flow [Single Tenant]
Matt Meeboer
Matt Meeboer
FME Version
  • FME 2023.0
This article will walk through configuring a SharePoint Online web service for FME Flow (formerly FME Server) using a single tenant Microsoft Azure app and your own Client ID. If you’re not sure what the difference is, please review the Microsoft documentation on tenancy. If you are configuring for multitenant, please see How to Create a SharePoint Web Connection for FME Flow [Multitenant].
These instructions are applicable for the SharePoint web connection used by the Microsoft SharePoint Reader/Writer and Microsoft SharePoint Online Connector from the FME Hub, but please note that a different web service template is used for each.
If you are unsure whether you should be using the SharePoint Reader/Writer or the SharePoint Online Connector, please refer to this article: SharePoint List Reader or SharePoint Online Connector - which should I use?
Please note that Azure is subject to change at any time, so the instructions and screenshots in this article may be slightly different, but the concepts remain the same.
Requirements
Modify the Azure App Registration
To successfully use your SharePoint Web Connection on FME Flow, your app registration must include the web as a platform with a valid redirect URI and have a Client Secret. If you have already created an app registration in Azure in FME Form, then you can modify it to work with FME Flow.  If you do not yet have an Azure App Registration or SharePoint Web Connection in FME Form, complete the steps in this article first: How to Create a SharePoint Web Connection for FME Form [Single Tenant]
1. Open the  Application Registration in the Azure Portal
Log in to the Azure portal and go to App Registrations.
App Registration
Click on your single tenant app registration to open it.
Edit App Registration
2. Add the Web Platform and Redirect URI
Click Authentication and then Add a platform. Choose Web.
Add Web Platform
For the redirect URI, enter your FME Flow URL followed by /fmeoauth. For example, https://myfmeserver.mydomain.com/fmeoauth. Note that your FME Flow instance must be configured to use HTTPS
Click Configure.
Configure Redirect URI
You should now see Web added with the redirect URI. You can add additional redirect URIs for other Instances of FME Flow that you plan to use the SharePoint connection on.
Redirect URI
3. Create a New Client Secret
To connect to SharePoint from FME Flow, you must have a client secret. This is not required in FME Form, only FME Flow.
Microsoft requires a client secret for confidential web apps (and this should not be used in a native app, like FME Form).
Click Certificates & secrets and then New client secret.
Add Client Secret
Give your client secret a description and expiry. Click Add.
Important: once your client secret expires, you will need to create a new one and update your FME  Flow web service to continue connecting to SharePoint.
Client Secret Expiry
After clicking Add, make sure to copy the secret value (not the Secret ID) and store it in a safe place, like a password manager. You will only get one chance to save the secret value! You can create another secret if needed.
Copy Client Secret Value
Your single tenant Azure app registration is ready for FME Flow.
Publish to FME Flow and Modify the Web Service(s)
If you have followed the instructions in How to create a SharePoint Web Connection for FME Form [Single tenant], then you should have a working web connection and web service to publish to FME Flow. If not, follow the instructions in the article linked above before proceeding.
1. Publish to FME Flow
In FME Form, open a workspace using the SharePoint List Reader/Writer and/or the SharePoint Online Connector (depending on which your workflow requires). Click the publish button.
Publish to Flow
Proceed through the publish wizard. On the Upload Connections step, make sure to enable the new SharePoint connection(s) you have created. This will upload both the web connection and its underlying web service to FME Flow.
Upload Connections
If you are using the SharePoint Online Connector from the FME Hub, you will also need to upload the SharePoint Online package.
Upload Package
Click Publish to complete the publish wizard and publish the workspace, connections and package to FME Flow.
2. Modify Web Service on FME Flow
Log in to FME Flow. From the side menu, click Connections & Parameters. If you’re using a version of FME Flow prior to 2023, click Files & Connections. You should see the connection(s) you published from FME Form and their associated web services. Click Manage Web Services.
Manage Web Services
Click on the web service you want to edit. In this example, the web service for the list reader and writer, however the process is the same for web connections used by the SharePoint Online Connector.
Edit Web Service
Fill in the details for your web service:
  • Description (optional): it’s recommended to update the description so that it reflects the Azure app name and tenant used by this web service
  • Client Id: this should already be present and match the Application (client) ID from your Azure app.
  • Client Secret: the client secret value from your Azure app, found in Certificates & Secrets. If you did not save the value when you first created the secret, you will need to create another in Azure.
  • Authorization URL: the Redirect URI, ending in fmeoauth, for your FME Flow instance. This was added to the web platform in your Azure app under Authentication in a prior step. For example, https://myfmeserver.mydomain.com/fmeoauth
Edit Web Service
Click OK to save the changes.
3. Authorize the Web Connection on FME Flow
Return to the Web Connections page. Click on the web connection associated with the web service.
Edit Web Connection
Click Authorize. You will be prompted to log in with your Microsoft SharePoint credentials and accept the Azure app’s requested permission. Once authorized successfully, the web connection will have a green checkmark. Click OK to close the web connection.
Authorize Connection
The SharePoint web connection will now work on FME Flow.
Repeat the same process of modifying the web service and authorizing the web connection for your second SharePoint connection, if you have one.
Comments
2 comments
  • Comment author
    Liz Sanderson
    Thanks for the feedback - the link has been fixed.
    0
  • Comment author
    dbryantgeo dbryantgeo
    The link to the How to Create a SharePoint Web Connection for FME Form [Single Tenant] article is incorrectly set to How to Create a SharePoint Web Connection for FME Flow [Single Tenant]
    0
