Unable to Run Workspaces Registered to Notification Service When SSL is Configured
Liz Sanderson
Liz Sanderson
FME Version
Symptom
When FME Server is configured to use SSL for client-server communication, workspaces registered to the Notification Service may not run.
Cause
This issue is caused by security rules imposed by the Apache Tomcat application server that runs the Notification Service. The server rejects the self-signed certificate that was created when SSL was configured on the application server.
Resolution
On the machine where FME Server is installed, run the following Java keytool command:
keytool -import -v -trustcacerts -alias server-alias -keystore "%JAVA_HOME%\jre\lib\security\cacerts" -file <your self-signed certificate> -keypass <key password> -storepass <keystore password>
This command imports the untrusted certificate into the FME Server database and instructs the web application server to make an exception for it.
Comments
0 comments
