Can I Change the Location of the FME Flow System Share Directory?
Liz Sanderson
Liz Sanderson
Can I change the location of the FME Flow (formerly FME Server) System Share Directory after Installation?
Answer
No. Changing the FME Flow System Share Directory Location requires reinstalling FME Flow.
This is due to multiple complexities and dependencies related to the location of the System Share. The System Share directory is where FME Flow stores commonly accessed files such as logs and resources. The default location of this directory is C:\ProgramData\Safe Software\FME Flow\ – and please note that the ProgramData directory is often hidden by default in the Windows File Explorer.
Changing the System Share Directory Location by Upgrading
See our documentation on Upgrading FME Flow to change the System Share Directory. The location you wish to change to must be specified during the FME Flow installation process. Changing the directory after installation is not supported.
See the example screenshots below from Custom and Express installations of FME Flow where the System Share location can be changed.
Image 1: Distributed/Fault Tolerant installation of FME Flow
Image 2: Express installation of FME Flow
Moving FME Flow System Share to Another Machine
To change the system share directory from one machine to a different machine, see our documentation on Moving the FME Flow System Share to Another Machine .
