Known Issue: Failed to load object data handling module adding Autodesk AutoCAD Map 3D Object Data Reader
Liz Sanderson
Liz Sanderson
Known Issue ID
FMEENGINE-66765
Feature Autodesk AutoCAD Map 3D Object Data Reader
Product FME Form (formerly FME Desktop)
Versions Affected
2020.x
2019.x
2018.x
Status
Resolved
2021.0
Issue
A user is unable to add an Autodesk AutoCAD Map 3D Object Data Reader (AUTOCAD_OD) but the user can add an AutoCAD RealDWG reader. The following error is received:
Error Message:
Object Data Reader: Failed to load object data handling module. No object data will be read
Failed to obtain any schemas from reader 'AUTOCAD_OD' from 1 datasets. This may be due to invalid datasets or format accessibility issues due to licensing, dependencies, or module loading. See logfile for more information
Cause
The error may be due to an incompatibility with the reader's third-party library and the Windows language format settings. The following languages are known to cause this issue:
  • English (Austria)
  • English (Denmark)
  • English (Finland)
  • English (Germany)
  • English (Netherlands)
  • English (Slovenia)
  • English (Sweden)
  • English (Switzerland)
  • English (United Arab Emirates)
If you encounter this error with a language that is not on this list please leave a comment on the article.
Resolution
This issue has been resolved in FME 2021.0.
If you are not able to upgrade, please follow the below steps to resolve the issue:
  1. Open the Windows Region settings via: Control Panel > Change date, time, or number formats > Formats tab
  2. Update the Format setting to another format display language. We’d recommend setting it to “Match Windows Display Language (recommended)”.
    If the format language is already set to “Match Windows Display Language (recommended)” OR set to one listed in the previous section, please set it to another format, such as “English (Canada)” or “English (United States)” as we know these do not cause an error.
If you are still experiencing a problem with adding an AutoCAD Map 3D Object Data reader, please contact Safe Support.
Comments
0 comments
