Safe Software Participation in OGC Pilots
Safe Software has participated in a number of Open Geospatial Consortium (OGC) pilots related to disaster response and climate resilience . The OGC initiates these pilots to bring together a wide range of specialists from various disciplines to explore which data sources and workflows are needed to support indicators and decision-making to adequately address disaster and climate change impacts. The challenge is to develop methodologies and tools for discovering, extracting, integrating, processing, and sharing information across spatial data infrastructures, using open standards, in the service of more effective disaster management and climate resilience.
There are ever-increasing volumes of data, much of it changing over time. However, all this can lead to information overload as managers are swamped with data from multiple domains and sources, and struggle to filter and interrelate it to extract meaningful, actionable knowledge. Thus, it is essential that the disaster managers find ways to improve their effectiveness and efficiency for integrating, combining, and leveraging spatial data, in order to better support effective climate change impact analysis that empowers the anticipation, response to, and mitigation of the effects. Safe Software participates in these pilots to learn more about these challenges and explore ways the FME platform can be used to meet these demands effectively and efficiently.
The following pilots each focus on a specific area of disaster or climate impact management. Follow the links to find out more information related to each pilot.
Disaster Pilot 2021
Model flood risk for the Red River Basin and feed this information to a transportation model to support flood mitigation routing.
Climate Resilience Pilot 2023
Provide a queryable service to extract climate model forecasts and produce results that are easy to access via GIS systems and incorporate into disaster planning and climate resilience analysis.
Disaster Pilot 2023
This pilot involves refining the climate services made available in the Climate Resilience Pilot and applying them to drought modelling in southern Manitoba. This pilot is ongoing, and an article will be published and linked here once the pilot wraps up.
AI-DGGS Disaster Pilot 2025
This pilot explored Discrete Global Grid Systems and their applicability to climate and disaster management scenarios. Using FME Flow's Data Virtualization platform, an OGC - DGGS API was created, along with 4 new custom transformers for integrating DGGS grids.
OGC AI-DGGS Disaster Pilot 2025
For more on FME's support for open standards and the OGC, see:
