JavaScriptCaller Transformer Deprecation
Liz Sanderson
Liz Sanderson
FME Version
Safe Software is taking steps to deprecate the JavaScriptCaller transformer. It will be phased out in a series of stages. This article explains the reasoning and timeline for this deprecation.
Justification
The JavaScriptCaller has a number of problems that currently reduce its usefulness.
Some of these issues are:
  • The transformer does not work in some Server contexts.
  • The transformer requires a major upgrade to continue to work on the macOS platform.
  • The transformer requires Python 2.7 to build, which is itself being deprecated.
Resolving these issues and keeping the maintenance up-to-date cannot, sadly, be justified by its current use statistics.
Timeline
The intended deprecation timeline is as follows:
FME2018.x
In FME2018 (FME2018.1.1, build 18579 onwards)...
  • A workspace using this transformer causes a warning message to occur in the log:
"The JavaScriptCaller transformer will be removed in FME 2020. Please consider migrating to a PythonCaller or other solution to avoid future inconvenience"
FME2019
In FME2019...
  • The transformer will be completely removed from macOS installations.
    • Once the transformer is completely removed from a platform it will not be possible to add a new instance, and a workspace containing the transformer will not operate.
  • The transformer will remain operable in Windows and Linux installations, but will be hidden from the Workbench interface so that new instances cannot be added.
  • No faults will be fixed or enhancements made to the transformer.
FME2020+
In FME2020 and beyond...
  • The transformer will be completely removed from all platforms.
    • Once the transformer is completely removed it will not be possible to add a new instance, and a workspace containing the transformer will not operate.
Alternatives
The FME support team is available to help with any questions about this deprecation, involving alternative solutions to current JavaScriptCaller use.
Comments
0 comments
