FME Version
Symptom
If a workspace contains a Datetimestamper and ArcPy, the datetimestamper will not work if the language is set to French Canadian. The output of the datetimestamper will be set to Null. This was found by a customer using 2019.1 and is still a problem.
Cause
The cause of this issue is currently unknown.
Resolution
Switching the language of the Window machine to English resolves the issue.
Comments
0 comments
