FME Flow Troubleshooting: FMEFlowJobSubmitter
Liz Sanderson
Liz Sanderson
Full Guide: FME Flow Troubleshooting Guide
Are you encountering issues submitting jobs with the FMEFlowJobSubmitter (formerly FMEServerJobSubmitter)? Please read below for some common troubleshooting tips, questions, and resources.
Content Overview
Terminology
Parent Workspace The Workspace that contains the FMEFlowJobSubmitter transformer.
Child Workspace The Workspace that is being submitted by the FMEFlowJobSubmitter transformer.
In 2023, FME Server underwent a name change and is now known as FME Flow. Since this article discusses features present in previous versions of FME, it will refer to both names interchangeably, using the appropriate product name based on the year the feature was introduced. For more information on the rebranding, see our website.
As of FME 2025.2, the term "Published Parameters" has been renamed in both FME Form and FME Flow.
  • In FME Form, "Published Parameters" are now called Visible Parameters and "Private Parameters" are now called Hidden Parameters.
  • In FME Flow, "Published Parameters" are now simply called User Parameters.
This terminology is still in the process of changing, so older versions may still reference "Published Parameters".
Initial Troubleshooting
  • Can you successfully run the child workspace on FME Flow (formerly FME Server) from the Run Workspace page? I.E., not submitted via the parent workspace. If not, focus your troubleshooting efforts here first.
  • Can you successfully use the FMEFlowJobSubmitter to submit austinApartments.fmw from the Samples Repository? If you can, consider what is different with your workspace; are you passing the correct values for user parameters?
  • Check for errors in the following logs
    • The parent/child job logs from the Jobs > Completed page.
    • The fmeserver.log from Resources > Logs > Core > Current|Old
    • The fmeprocessmonitorengine.log from Resources > Logs > Engine > Current|Old
Common Issues
“The FMEFlowJobSubmitter fails to authenticate using an FME Flow Web Connection with Reason - credentials for user are invalid”
There is a known issue with the FME Flow transformers refreshing the token for an FME Flow Web Connection in Please see this article for more information.
“The child workspace fails to run with the error: 'Failed to submit request to run workspace 'MyWorkspace.fmw' in repository 'MyRepository' FMEFlowJobSubmitter (ServerFactory): Reason - MyUser is not authorized to perform this action'”
This error is typically caused by improper user account permissions or network proxy settings.
Please confirm that the account has correct permissions by one of the three tests:
  1. Logging into FME Flow with that user account and running the child workspace.
  2. Using a different account with more extensive permissions in the FMEFlowJobSubmitter
  3. Temporarily grant the account All Permissions in the FMEFlowJobSubmitter, or confirm that they have access to all permissions required to run that workspace.
If your FME Flow is using a system proxy, please check the proxy exception list from the Web UI: Admin > Network & Email > Proxy. Within the "No Proxy For" parameter, please try adding your FME Flow domain in different formats, e.g., localhost, 127.0.0.1, *.example.*, MyHostname.MyDomain.*
“My child workspace is stuck in the QUEUED state”
There are a few known reasons why a workspace submitted by the FMEFlowJobSubmitter may get stuck in the queue:
  1. The parent workspace contains multiple FMEFlowJobSubmitters, and the child workspaces being submitted are using different versions of Python. Please see this article for more information.
  2. Your FME Flow is licensed with one engine, and your FMEFlowJobSubmitter is configured with Wait for Jobs to Complete: Yes and Submit Jobs: In Parallel. Please see this article under the heading ‘The Engines are occupied by other Jobs’ for more information. For ideas on workflow management, check out this article.
  3. There are no engines assigned to the Queue configured in the FMEFlowJobSubmitter. Please see this article under the heading ‘The User-Defined Queue has not been assigned Engines’ for more information.
"My fmeserver.log reports 'Missing or expired workspace chaining context' for a child engine process"
In your FMEFlowJobSubmitter, when Wait for Jobs to Complete: Yes and Submit Jobs: In Parallel are set, this launches a temporary child engine process. If the child engine loses connection with the parent, this process endlessly tries to restart. Please see this article for more information.
“How can I use a SAML account to authenticate an FMEFlowJobSubmitter?”
Submission Mode Configuration 2017 and newer
Submit Jobs: In Sequence
  • Submits one job at a time. Each job is submitted after the previous job finishes.
  • A sub-engine process is spun up to run the child workspaces. This engine has the name Engine<N>@Job<ID> where N is the name of the Engine the Parent Job is running on and ID is the Parent Job ID.
  • Child workspaces are submitted under a new Job ID -  they will be listed as separate records on the Completed Jobs page and have their own log.
  • Waits for all jobs to enter the transformer and then submits them all at once. Features are sent from the Success port of the transformer once all jobs have finished.
  • Jobs will be run on all available engines assigned to the associated queue.
Wait for Jobs to Complete: No
  • Submits one job at a time. Features are released from the output port as soon as the job is submitted.
  • Waits for all jobs to enter the transformer and then submits them all at once. Features are sent from the Submitted port as soon as they are submitted.
Are you still experiencing issues?
Please consider posting to the FME Community Q&A if you are still experiencing issues that are not addressed in this article. There are also different support channels available. When contacting support, please share the job log from the parent and child workspace.
Have ideas on how to improve this?
You can add ideas or product suggestions to our Ideas Exchange.
