Rebrand Installer for 2024.0
Kezia Yu
Kezia Yu
What’s changed in the rebrand installer for 2024.0? Will this break my workflows?
 Answer
There should be no changes to functionality, including silent installations. Refer to the list below for a summary of the changes.
  • IDs of features in the installer renamed
    • FMEServerCore → FMEFlowCore
    • FMEServerDatabase → FMEFlowDatabase
  • Installer properties names
    • FMESERVERHOSTNAME → FMEFLOWHOSTNAME
    • FMESERVERHOSTNAMELOCAL → FMEFLOWHOSTNAMELOCAL
    • FMESERVERUSER → FMEFLOWUSER
    • FMESERVERUSERPASSWORD→ FMEFLOWUSERPASSWORD
    • FMESERVERSHAREDDATA → FMEFLOWSHAREDDATA
    • FMESERVERBUILD → FMEFLOWBUILD
    • FMESERVERREQUESTPORT → FMEFLOWREQUESTPORT
  • Config files renamed in <FMEFlowDir>\FMEFlow\Server or /opt/fmeflow/Server
    • fmeServerConfig.txt → fmeFlowConfig.txt
    • fmeServerWatcherConfig.txt → fmeFlowWatcherConfig.txt
    • fmeServerWebApplicationConfig.txt → fmeFlowWebApplicationConfig.txt
  • Database name
    • fmeserver → fmeflow
Windows Specific
  1. FME Flow Windows Services
  • FME Server Application Server → FME Flow Application Server
  • FME Server Core → FME Flow Core
  • FME Server Database → FME Flow Database
  • FME Server Engines → FME Flow Engines
  1. FME Java process names in Task Manager
  • FMEServer.exe → FMEFlow.exe
  • FMEServer_ApplicationServer.exe → FMEFlow_ApplicationServer.exe
  1. bat files in C:\Program Files\FMEFlow\Server\WindowsService
  • startFMEServerWindowsService.bat → startFMEFlowWindowsService.bat
  • restartFMEServerWindowsService.bat → restartFMEFlowWindowsService.bat
  • stopFMEServerWindowsService.bat → stopFMEFlowWindowsService.bat
Linux Specific
  1. Systemd/SysV script names
systemd scripts:
<FMEFlowDir>/Server/startup/systemd/fmeflow-appserver.service
<FMEFlowDir>/Server/startup/systemd/fmeflow-cleanup.service
<FMEFlowDir>/Server/startup/systemd/fmeflow-core.service
<FMEFlowDir>/Server/startup/systemd/fmeflow-database.service
<FMEFlowDir>/Server/startup/systemd/fmeflow-engines.service
<FMEFlowDir>/Server/startup/systemd/fmeflow-websocket.service
SysV scripts:
<FMEFlowDir>/Server/startup/SysV/FMEFlowAppServer
<FMEFlowDir>/Server/startup/SysV/FMEFlowCleanup
<FMEFlowDir>/Server/startup/SysV/FMEFlowCore
<FMEFlowDir>/Server/startup/SysV/FMEFlowDatabase
<FMEFlowDir>/Server/startup/SysV/FMEFlowEngines
<FMEFlowDir>/Server/startup/SysV/FMEFlowWebSocket
Place scripts in new paths:
/etc/init.d/FMEFlowAppServer
/etc/init.d/FMEFlowCleanup
/etc/init.d/FMEFlowCore
/etc/init.d/FMEFlowDatabase
/etc/init.d/FMEFlowEngines
/etc/init.d/FMEFlowWebSocket
  1. User and group
  1. NGINX config file and location
  • fmeserver.conf → fmeflow.conf
  •  /etc/nginx/fmeserver →  /etc/nginx/fmeflow
