SchemaMapper Use Case Example
Brian Pont
Brian Pont
Use Case
The attached workspace provides an example workspace showing thirteen different ways to use the SchemaMapper transformer.
The various uses of the SchemaMapper demonstrated in the workspace are:
Type 1: Simple feature type to feature type mappings (1:1)
Type 2: Feature type to feature type where one features maps to many features
 1:M feature mapping based on a source attribute value
Type 3: Feature type to feature type where many features map to a single feature
 M:1 feature mapping
Type 4: Attribute to attribute mapping
 1:1 attribute mapping
Type 5: The same attribute (type) in different tables map to different attributes in the destination feature type i.e.
 Pole/type > pole_type
 Manhole/type > manhole_type
 Multple entries per attribute, based on feature
Type 6: Attributes in a table map to the different attributes based on the value of the source attribute i.e.
 Pole/type = 1 > pole_type = 1
 Pole/type = 2 > material = 2
 Multiple entries per attribute, based on feature & value
Type 7: Attributes in a table map to the different attributes based on the value of the source attribute i.e.
Type 8: Feature & attribute mapping
 Feature to feature mapping 1:1
 Attribute to attribute mapping 1:1 i.e.
 Pole/typeA  > pole_type
 Pole/typeB  > material
Type 9: Simple attribute value mapping (domain mapping) Requires a separate schemamapper for each domain (basically the idea is that this could be a dynamic ValueMapper)
Type 10: Attribute value mapping
 Value mapping 1:1
 type X > A
 type Y > B
 material X > A
 material Y > B
Type 11: Attribute value mapping - for several different attributes for different feature types.
 Value mapping 1:1
 Pole type X > A
 Pole type Y > B
 Pole  material X > A
 Pole  material Y > B
 Manhole type u    >  1
 Manhole  type v   >  2
Type 12: Attribute value mapping - for several different attributes for different feature types.
 Value mapping 1:1
 Pole  type X > pole_type A
 Pole  type Y > pole_type B
 Pole  material X > material_type A
 Pole  material Y > material_type B
 Manhole type u > manhole_type 1
 Manhole  type v > manhole_type  2
Type 13: Attribute value mapping - for several different attributes for different feature types. attribute to attribute mapping 1:1 value mapping 1:1
 Pole  type X > supportStructures pole_type A
 Pole  type Y > supportStructures pole_type B
 Pole  material X > supportStructures material_type A
 Pole  material Y > supportStructures material_type B
 Manhole type u > AccessPoint manhole_type 1
 Manhole  type v > AccessPoint manhole_type  2
